Case statement not working
Discussion in 'SQL Server Scripts and Tools' started by Makis Best, Oct 24, 2012.
  1. Makis Best
    Makis Best New Member
    Hi all
    I have this Case statement but seems not working, can anyone help with the script?
    Code (text):
    Select LItmSale.name,
    CASE LItmSale.LinkID
        WHEN 001 THEN (SELECT Price FROM ItemPrc WHERE PriceListAA = 39 AND PriceCtgr = 'Team1' AND ServiceID = 100.001)
        WHEN 002 THEN (SELECT Price FROM ItemPrc WHERE PriceListAA = 39 AND PriceCtgr = 'Team1' AND ServiceID = 100.002)
        WHEN 003 THEN (SELECT Price FROM ItemPrc WHERE PriceListAA = 39 AND PriceCtgr = 'Team1' AND ServiceID = 100.003)
        WHEN 004 THEN (SELECT Price FROM ItemPrc WHERE PriceListAA = 39 AND PriceCtgr = 'Team1' AND ServiceID = 100.004)
        WHEN 005 THEN (SELECT Price FROM ItemPrc WHERE PriceListAA = 39 AND PriceCtgr = 'Team1' AND ServiceID = 100.005)
        WHEN 006 THEN (SELECT Price FROM ItemPrc WHERE PriceListAA = 39 AND PriceCtgr = 'Team1' AND ServiceID = 100.006)
        WHEN 008 THEN (SELECT Price FROM ItemPrc WHERE PriceListAA = 39 AND PriceCtgr = 'Team1' AND ServiceID = 100.008)
        WHEN 016 THEN (SELECT Price FROM ItemPrc WHERE PriceListAA = 39 AND PriceCtgr = 'Team1' AND ServiceID = 100.016)
        WHEN 017 THEN (SELECT Price FROM ItemPrc WHERE PriceListAA = 39 AND PriceCtgr = 'Team1' AND ServiceID = 100.017)
        WHEN 018 THEN (SELECT Price FROM ItemPrc WHERE PriceListAA = 39 AND PriceCtgr = 'Team1' AND ServiceID = 100.018)
        ELSE 0
    END as VALUES
    from litmsale
    I get no error
    The selects return null when I run the script.
    When I run every select in parenthesis individual the return value is correct.
    If I replace any select with the number 1 then the script runs OK and returns the value 1 correct but when run with the select returns null.
    Please help.
    Thank you
  2. Peter Schmitz
    I tested this with some testdata, and apart from having to wrap the "VALUES" in squarte brackets (i.e. [VALUES]), the script worked fine for me.The brackets are required due to VALUES being a reserved SQ Server keyword.
    One thing that might cause some error is that the value of ServiceID contains a period (.). What data type did you define the column as?
  3. Makis Best
    The column data are Int.
    I try your propulsive and it works.
    Thank you
