DTS Run Error: activeX component can't create object when running DTS
Discussion in 'General' started by Grand Wavine, Jun 22, 2017.
  1. Grand Wavine
    Grand Wavine New Member
    I can run the VB Script that runs a DTS from the SQL Server, however running the same VB Script to to execute the DTS from a client PC has the above error message. I have tried, installing MS SQL studio on the client connecting to the DB instance and tried running the VB Script but it still wont work. im lost, please help
    Regards,
    Grand
  2. Peter Schmitz
    Hi Grand,
    What dlls are being used by the VB Script? What does the script do? Could you show the code?
    Thanks!
    Peter
