| Field | Description |
| @ActiveConnections | The number of active connections to the database. |
| @AnsiNullDefault | Specifies whether the ANSI_NULL_DEFAULT database option is active. |
| @AnsiNullsEnabled | Specifies whether the ANSI_NULLS_ENABLED database option is active. |
| @AnsiPaddingEnabled | Specifies whether the ANSI_PADDING_ENABLED database option is active. |
| @AnsiWarningsEnabled | Specifies whether the ANSI_WARNING_ENABLED database option is active. |
| @ArithmeticAbortEnabled | Specifies whether the ARITHMETICABORT database option is active. |
| @AutoClose | Specifies whether the AUTOCLOSE database option is active. |
| @AutoCreateStatisticsEnabled | Specifies whether statistics are automatically created for the database. |
| @AutoShrink | Specifies whether the AUTOSHRINK database option is active. |
| @AutoUpdateStatisticsAsync | Specifies whether the AUTOUPDATESTATISTICSASYNC database option is active. |
| @AutoUpdateStatisticsEnabled | Specifies whether statistics are automatically updated for the database. |
| @BrokerEnabled | Specifies whether the Service Broker service is enabled. |
| @CaseSensitive | Specifies whether uppercase letters and lowercase letters are evaluated as equal. |
| @ChangeTrackingAutoCleanUp | Gets the Boolean property value that specifies whether change tracking data is automatically cleaned up after the configured retention period. |
| @ChangeTrackingEnabled | Gets the Boolean property value that specifies whether change tracking is enabled. |
| @ChangeTrackingRetentionPeriod | Gets the retention period specifying how long the change tracking data is kept in the database if autocleanup is being used. |
| @ChangeTrackingRetentionPeriodUnits | Gets the unit of time for the change tracking retention period. |
| @CloseCursorsOnCommitEnabled | Specifies whether the CURSOR_CLOSE_ON_COMMIT database option is active. |
| @Collation | The default collation used by the database. |
| @CompatibilityLevel | The compatibility level for the database. |
| @ConcatenateNullYieldsNull | Specifies whether the CONCAT_NULL_YIELDS_NULL database option is active. |
| @CreateDate | The date that the database was created. |
| @DatabaseGuid | The GUID value that uniquely identifies the database. |
| @DatabaseOwnershipChaining | Specifies whether the database ownership chaining is active. |
| @DatabaseSnapshotBaseName | The name of the snapshot base for the database. |
| @DataSpaceUsage | The space used by the data in the database. |
| @DateCorrelationOptimization | Specifies whether the date correlation optimization is active. |
| @DboLogin | Specifies whether the current user is logged on as the database owner (DBO). |
| @DefaultFileGroup | The default file group used by the database. |
| @DefaultFileStreamFileGroup | Gets the filegroup name for the default FILESTREAM filegroup. |
| @DefaultFullTextCatalog | The default full-text catalog used by the database. |
| @DefaultSchema | The default schema of the user. |
| @EncryptionEnabled | Gets the Boolean property value that specifies whether the database is enabled for transparent data encryption. |
| @HonorBrokerPriority | Specifies whether the priority is taken into consideration for service broker. |
| @ID | The database ID value that uniquely identifies the database. |
| @IndexSpaceUsage | The space used by the indexes in the database. |
| @IsAccessible | Specifies whether the database can be accessed. |
| @IsDatabaseSnapshot | Specifies whether the database is a snapshot database. |
| @IsDatabaseSnapshotBase | Specifies whether the database is the base database for a snapshot database. |
| @IsDbAccessAdmin | Specifies whether the current user is a member of the DbAccessAdmin database role. |
| @IsDbBackupOperator | Specifies whether the current user is a member of the DbBackupOperator database role. |
| @IsDbDatareader | Specifies whether the current user is a member of the DbDatareader database role. |
| @IsDbDataWriter | Specifies whether the current user is a member of the DbDatawriter database role. |
| @IsDbDdlAdmin | Specifies whether the current user is a member of the DbDdlAdmin database role. |
| @IsDbDenyDatareader | Specifies whether the current user is a member of the DbDenyDatareader database role. |
| @IsDbDenyDatawriter | Specifies whether the current member is a member of the DbDenyDatawriter database. |
| @IsDbOwner | Specifies whether the current user is a member of the DbOwner database role. |
| @IsDbSecurityAdmin | Specifies whether the current user is a member of the DbSecurityAdmin database role. |
| @IsFullTextEnabled | Specifies whether the database is enabled for full-text search. |
| @IsMailHost | Specifies whether the database is configured as a mail host. |
| @IsManagementDataWarehouse | Specifies whether the database is configured as a Management Data Warehouse. |
| @IsMirroringEnabled | Specifies whether mirroring is enabled on the database. |
| @IsParameterizationForced | Specifies whether parameterization is forced on the database. |
| @IsReadCommittedSnapshotOn | Specifies whether the database is enabled for read-committed isolation using row versioning. |
| @IsSystemObject | Specifies whether the database is a system object or a user-defined database. |
| @IsUpdateable | Specifies whether the database can be updated. |
| @IsVerDecimalStorageFormatEnabled | Specifies whether the database is enabled for vardecimal storage format. |
| @LastBackupDate | The date and time when the database was last backed up. |
| @LastDifferentialBackupDate | The date and time when the last differential backup was performed. |
| @LastLogBackupDate | The date and time when the transaction log was last backed up. |
| @LocalCursorsDefault | Specifies whether the local server cursors are used by default. |
| @LogReuseWaitStatus | The type of operation on which the reuse of transaction log space is waiting. |
| @MirroringFailoverLogSequenceNumber | The log sequence number at last failover. |
| @MirroringID | The ID value that uniquely identifies the mirroring partnership. |
| @MirroringPartner | The address of the Database Engine instance that is the partner server for database mirroring. |
| @MirroringPartnerInstance | The instance of SQL Server on which the mirroring partner is configured. |
| @MirroringRedoQueueMaxSize | The maximum size of the redo queue of the mirror server instance in KB. |
| @MirroringRoleSequence | The role sequence number for primary/backup roles played by the mirroring partners. |
| @MirroringSafetyLevel | The mirroring safety level. |
| @MirroringSafetySequence | The role sequence number for safety levels for the mirroring partners. |
| @MirroringStatus | The status of the database and the database mirroring session. |
| @MirroringTimeout | The maximum time, in seconds, that the principal server instance waits for a PING message from another instance in the mirroring session before assuming the other instance is disconnected. |
| @MirroringWitness | The name of the database-engine instance of the database mirroring witness server. |
| @MirroringWitnessStatus | The status of the mirroring witness server. |
| @Name | Gets or sets the name of the object.(inherited from NamedSmoObject) |
| @NumericRoundAbortEnabled | Specifies whether the NUMERIC_ROUNDABORT database option is active. |
| @Owner | The database principal that is the owner of the database. |
| @PageVerify | Specifies the type of page integrity check that Microsoft SQL Server performs when reading database pages. |
| @PrimaryFilePath | The path and name of the operating system directory that contains the primary file for the database. |
| @QuotedIdentifiersEnabled | Specifies whether identifiers delimited by double quotation marks (" ") are Transact-SQL reserved keywords or contain characters not usually allowed by the Transact-SQL syntax rules. |
| @ReadOnly | Specifies whether the database is read-only. |
| @RecoveryForkGuid | The GUID value that specifies the recovery fork on which the database is currently active. |
| @RecoveryModel | The recovery model for the database. |
| @RecursiveTriggersEnabled | Specifies whether recursive triggers are enabled on the database. |
| @ReplicationOptions | The active replication settings for a database, |
| @ServiceBrokerGuid | The Guid object that uniquely identifies the instance of MicrosoftService Broker. |
| @Size | The size of the database in megabytes. |
| @SnapshotIsolationState | The snapshot isolation state for the database. |
| @SpaceAvailable | The available space in the database in kilobytes. |
| @Status | The database status. |
| @Trustworthy | Specifies whether the trustworthy property is set. |
| @UserAcces | The database user access. |
| @UserName | The name of the database user. |
| @Version | The version of the instance of SQL Server that was used to create the database. |
