Clustered vs Nonclustered indexes
Discussion in 'General' started by freiheitpt, May 10, 2013.
  1. freiheitpt
    freiheitpt New Member
    Hello all,
    Well, as an asignment, we have to measure how much time it takes to insert 100000 rows of data in a database... the primary keys indexes (4 seperate tests) are the following:
    Code (text):
    ALTER TABLE company.employee
    ADD CONSTRAINT pk PRIMARY KEY CLUSTERED (ssn) WITH (FILLFACTOR=100, PAD_INDEX=ON);
    GO
    ADD CONSTRAINT pk PRIMARY KEY CLUSTERED (ssn) WITH (FILLFACTOR=80, PAD_INDEX=ON);
    GO
    ADD CONSTRAINT pk PRIMARY KEY NONCLUSTERED (ssn) WITH (FILLFACTOR=100, PAD_INDEX=ON);
    GO
    ADD CONSTRAINT pk PRIMARY KEY NONCLUSTERED (ssn) WITH (FILLFACTOR=80, PAD_INDEX=ON);
    GO
    the table is:
    Code (text):
    CREATE TABLE company.employee (
        Fname        VARCHAR(15)        NOT NULL,
        Minit        CHAR,
        Lname        VARCHAR(15)        NOT NULL,
        Ssn            INT                NOT NULL /*PRIMARY KEY*/,
        Bdate        DATE,
        Address        VARCHAR(30),
        Sex            CHAR,
        Salary        DECIMAL(10,2),
        Super_ssn    CHAR(9),
        Dno            INT                /*NOT NULL*/,
    GO
    and finaly this is the algorithm to insert the 100000 data rows:
    Code (text):
    DECLARE @start_time DATETIME, @end_time DATETIME;
    SET @start_time = GETDATE();
    DECLARE @temp int;
    SET @temp = 0;
    WHILE(@temp < 100000)
    BEGIN
        DBCC DROPCLEANBUFFERS;    -- Tem de ser administrador da SGBD
        BEGIN TRANSACTION Insert1;
        DECLARE @ssn int;
        SELECT @ssn = round(RAND()*987654321, 0);
        insert INTO company.employee values ('Maria', 'G', 'Sousa', @ssn, '2001-01-01', 'Rua XPTO', 'M', 1200, NULL, NULL);
        SET @temp +=1;
        COMMIT TRANSACTION Insert1;
    END;
    SET @end_time = GETDATE();
    PRINT 'Milliseconds used: '+CONVERT(VARCHAR(20), DATEDIFF(MILLISECOND, @start_time, @end_time)) + 'ms';
    GO
    --teste
    SELECT * FROM company.employee;
    GO
    now... the problem...
    in my server (on my laptop), the times are all equivalent (+/-230000ms).
    but the times given by the professor show that they should all be diferent, the first beeing the one which takes the most amount of time, and the last one the one wich takes the less amount of time.
    What could I be doing wrong?
    (note: even the professor doesnt know what is happening. the code is also more or less done by him. the idea here is to "learn" about the differences)
    Thanks!
