Odbc connection dont work
Discussion in 'General' started by ZionAssedo, Mar 15, 2016.
  1. ZionAssedo
    ZionAssedo New Member
    Hi,
    I'm running a MSSQL 2012 server in a 2012 R2 server in a VM and I want to create an odbc connection on my host computer.
    The IP address of my VM is 192.168.42.146 and I can ping the VM from the host as well, but when trying to establish an ODBC connection to the Sql server it fails.
    The Sql server instance name is WIN-74DOGP6POB3 so in the dsn wizard I specified \\192.168.42.146\WIN-74DOGP6POB3, what is wrong ?
    Help will be much appreciated.
  2. Peter Schmitz
    Hi!
    Try and remove the double slash in front of the IP-address. I.e. just supplying 192.168.42.146\WIN-74DOGP6POB3
    Hope this helps. If not, please show us some screenshots of how you're setting things up, and perhaps include the error message you receive.
    Thanks!
    /Peter
  3. ZionAssedo
    Hi Peter,
    I did what you suggested but it didnt help.
    The strange thing is that I can telnet the port as well also, here is the error message I get from the test connection :
